Unclamp/Clamp on yasnac lx3
Having a bit of a problem.
trying to run a bar feed job on a yasnac lx3 control. I have never run a barfeed on this machine since we got it. No electronics are hooked from the barfeed to the machine YET. its just the barfeed ONLY.
M11 opens chuck fine, however I cannot close chuck with M10. it hangs like its waiting for another code to be in before the M10.
I have tried
M05
G00 Z-0.450
M11
<<<<<<<<<<<<< tried a pause and tried a M00. it makes no difference it hangs right here and wont continue.
G00Z0.020
M10
Even tried a pause in there after the M11 (open chuck) and also tried a M00.
tried both MDI and a program, and chuck will open but not close, if the chuck is open and you punch in M10 it will hang, however if the chuck is closed and you punch in M10 (already closed) it will proceed to next lines.
I am guessing there is a parameter somehwere I am missing inside the control, or am I missing a Gcode somewhere.
if it makes a difference its on a slant50.
Delw
Re: Unclamp/Clamp on yasnac lx3
I had set parameter 7091 but M10 & M11 not work. It only buffer.
When chuck open, I call M10: Alarm 25 (chuck close not detected)
My machine: Hitachi NR20 (Yasnac LX3)
Can you help me!!!https://uploads.tapatalk-cdn.com/201...35295420e9.jpghttps://uploads.tapatalk-cdn.com/201...823dee7ac7.jpg
Sent from my MIX 2 using Tapatalk
