4 Attachment(s)
My version of the air ratchet drawbar
Hi Guys,
I decided last week to go with Tormach TTS tooling so I needed a powered draw bar of some type.
My machine is a round column and I have the ball screws driving the quill directly so any system that put a lot of down force on the draw bar was out.
With suggestions form the group in another thread I decided to use the 3/8" butterfly ratchet from Harbor Freight. It cost $25.00. I had to mount it to the belt cover so I could still open the top when needed. I used 3/8" id bushings and some old R/C car springs I had laying around. It works great, thanks for the suggestions guys.
Re: My version of the air ratchet drawbar
Quote:
Originally Posted by
skray775
I can shoot a little iPhone video later and post it.
My belt cover is steel so the mount is bolted to the cover with four 8/32" socket cap screws.
The upper plate is made from two parts of 1/4" aluminum simple because I did not have any 1/2" scrap around. A pair of 6/32" set screws hold the gun in place on the upper mount.
I am attaching the DXF file if anyone wants it.
Operation is simple, grab the gun, push it down, rotate the butterfly lever the direction you want it to spin. My machine is pretty small so it is always easy to reach and there is no enclosure so I did not need a remote air switch to activated it.
thank you for posting this
