Tormach PCNC 1100 Fourth Axis Table as a C Axis
The 8" rotary table manual from Tormach clearly specifies the table can be used as a C Axis. In other words, instead of using it in its vertical mode, I can use it in its horizontal mode. YOu may be asking why on Earth would I do this? It is a CNC Machine!!!!
Well, as it turns out, using a rotary table as a C axis is an excellent way of expanding the XY table size. For example, the Y can only traverse about 10". But if I displace the Y features into the X side, I can then run larger stuff.
So this is all good and dandy. The question is, how do I tell Sprutcam to orient the table in the C Axis instead of the A Axis? I woud imagine this is doable, right? Thanks for your input!
