thunder laser controller DF211 goes haywire
Hi
yesterday I turn on my converted K40 and the thunder controller DF211 goes haywire.
the day before it worked perfect and then it does everythings like there own mind. the home position is overshooting to the lower right even if it should be upper left, nothing could change this not reset or new load of manufacturer settings. turn off and on did not help ether. then I set the manufacturer settings to the lower right and then it goes to the upper left. checked the limit switches all OK . format the controller memory . reload the manufacturer settings and finally it worked again but what a surprice I load the first job what I did a few days ago and I did not trust my eyes it engraved mirrored .
I reloaded the file but still mirrored the I took another file load them and it did give the same result .
now I am out of Ideas how to fix this.
maybe some one has a solution
thanks
and happy easter
walt
