Trouble Shooting For Error Engraving On CNC Wood Router
2012-06-05 11:55:52 Browsing times:0
Troubleshooting for error engraving on cnc wood router
1. The engraved letters and graphs on cnc wood router are inconsistent with the typesetting sizes. Solution: In the disposition procession settings, set the resolution of the machine tool at: 80
2. Troubleshooting for step losses in any direction at X, Y and Z:
a. Check whether the guide rail in the direction is too tight, which causes step losses.
b. Check whether the step motor on cnc wood router in the direction is fast connected.
c. Check whether the special cables in the maneuvering box is properly connected, whether there is a pin retraction or disconnection. Replace it with a backup cable line and test it.
3. Troubleshooting for unsmooth engraved letter or graph contour:
a. Unscrew the cutter holder head, and turn around the cutter before reclamping, thus ensuring that the blades particpate in the cutting process.
b. Replace with new cutters.
c. Increase or decrease the speed of spindle of cnc wood router to adapt to different materials.
4. Troubleshooting for frequent breaking
a. Mount the cutter properly for its wide-range nose swinging movement can easily cause breaking.
b. Eliminate the clearances between slipways on X, Y and Z directional coordinates.
c. Increase of decrease the speed of spindle to adapt to different materials.
d. Decrease the cutting depth of one cut and separate the cutting into twice or several times.
e. Select the engraving knife with comparably large cutter angles.
f. Select the cutter with high quality for cnc wood router.
