5 Attachment(s)
GWEIKE LF10 metal fiber laser marking machine FOR METAL
Air cooled cooling systerm,easy and quickly installation,USB contacted with any computer and install softerware easily
Use interfaces types: text, graphics, serial number, serial number, a d bar code, 2 d barcode, successive signet (optional equipments),etc
Suitable for: anodized sculpture, hand tools deep carved, aluminum a deep carved, stainless steel surface carved black, IC table sculpture, etc.!
Advantages: small volume, avoid consumables, flexible degree is high, use 5-100000 hours and hours without power attenuation problem!
Main parts:
1.laser head can change manually by wheel
2.EzCad2.7.0 software&softdog
3.one set computer
4.3d removable working table
5.air cooling system
6.USB port
7.10/20W pulsed laser&laser power
Option parts:
1.UK SPI 10W pulsed laser&laser power
2.rotary attachment
Main specification:
Laser type:Ytterbium Fiber
Operation type:Q – switched
Laser power :10/20w
Each pulse energy (mj): 0.5 1
Laser wavelength (nm):1060 ~ 1070
Pulse wave frequency:20 ~ 80 KHz
working area 100*100mm/150*150mm
10 Attachment(s)
cnc router for marble 51*98
supply with CE certificate.
1.The machine adopts imported linear square and 4 lines double slider.Larege loading capacity,run stably,high precision,long life, accurate cutting.
2.The whole machine use seamless steel,bettter rigidity,working table backing steel plate,rigid strength and loading capacity of the machine can be more than 1000 KG.
3.Constant power spindle motor,powerful cutting intensty, high effeciency.
4.Good compatibility for CAD/CMD software,including Type 3,Artcam,Castmate,Artgrave etc.
5.The cooling system for tools improves its life.
Applicable materials:
Granite, marble, bluestone, sandstone, thin soft metal etc stone engraving
Density stone such as granite can be engraved to 3mm repeatedly
Some stone such as marble, bluestone can be engraved to 3mm at one time.
Specification:
1)X Y axis working area:1,300x3,500mm
2)Z axis working area:300mm
3)Table size:2,000x4,000mm
4)Max.speed:0-10,000mm/min
5)Max.working speed:0-3,000mm/min
6)Working delicacy:0.02mm
7)Reposition accuracy:0.05mm
8)Max.feeding height:300mm
9)Engraving Command:G code,u00,mmg,plt
10)Software:Type3,Artcam,Ncstudio software
11)Max.powerconsumption:6 KW
12)Spindle:1.5KW/2.2KW/3KW/4.5KW/HSD 1.5KW/HSD 3KW/HSD 4.5KW/HSD5.5KW/HSD 6KW/HSD 7KW variable speed, water cooled /air cooled
13)Spindle speed:18000/24,000rpm
14)Work type:stepper
15)Weight:1200kg
16)Working voltage AC380V,50/60Hz
17)Memory:32M
18)Manner of receiving data:USB orPCI
19)Running circumstance temperature: 0 - 45°C
20)Relative humidity: 30% - 75%
Jinan G.Weike Science & Technology Co.,Ltd.
Laser engraving machine|Laser cutting machine|CNC router-G.Weike Laser
Tel:+86-0531-88020976
Mobile:8615154147619
Fax:+86-0531-88912386
Email:[email protected]
6 Attachment(s)
51*98 woodworking cnc router
Supply with CE certificate
1.The max travelling speed can reach more than 30 meters/minute,the max cutting speed can reach 25 meters/minute.
2.Adoption of advanced DSP CNC system and make the operation more convenient.And its design provide more human nature.
3.Unique intelligent caculation rules can fully develop the potential of the motor,it also leads to high speed processing and the synchronization of curves and straight line.
4.Y axis adopts double motor driver.
5.Six districts vacuum table.
6.Professional 3D control system.
7.Equip CHINESE/HSD spindle motor,vacuum suction table,vacuum pump and dust collector.It is mainly applicable in the manufacture of furnitures,the wooden doors,pvc and other materials.
Specification:
X,Y axis working area: 1,300 x 2,500mm
Z axis working area: <200mm
Table size: 1,450 x 2,120mm
Max. speed: 0 - 30,000mm/min
Max. Working speed: 0 - 20,000mm/min
Working delicacy: 0.015mm
Reposition accuracy: 0.05mm
Max.Feeding height: 200mm
Command: G code*. u00*. mmg*. plt*. nc
Software: Type3, Artcut, Artcam, Ncstudio software
Max. power consumption: 3KW
motor Spindle speed: 24,000rpm
Work type: stepper (Option:servo)
Working voltage: AC 220V, 50/60Hz
Memory: 32M
Manner of receiving data: USB OR PCI
Weight:1400kg
[email protected]
2 Attachment(s)
cnc router for marble/for wood
