3 Attachment(s)
Need opinions on machine design
Hello everybody,
I'm starting on a router/milling machine and would like to hear some tips from you. I learned Solidworks and designed the machine here first.
It will be used on different materials, but mostly aluminium.
Router will be made of 20mm and 15 mm aluminium plates, Chinese 20 mm(x,y) and 16 mm (for z axis) supported rails, Chinese 16mm/5mm pitch ballscrews.
Probably I will use 1.5kw or 2.2kw, again, Chinese spindle and 300 oz/in motors.
Rail size is 750 mm 600mm and 300mm for Z axis.
Rails, screws, motors and controllers are already ordered.
Please check the attached pictures and see if you can find any flaws before i begin. All feedback is welcome.
