Baldor Vector Drive Problems
I have a Fadal VMC 15 built in 1995 with a Baldor vector drive labeled INV 0015. We work with this machine since 2001. In the first year of operation problems while tapping without compensation occured. So we changed to tapping with compensation device to avoid these problems. Last summer suddenly the spindle stops running. After re-booting the system and cooling down, the machine was working well for some minutes. The spindle stutters and than stops slowly. Spindle load was showing all LED s. The Fadal support in Germany gave me the advice to check all fans. And in fact the fan of the housing with the vector drive was out of order. We changed the fan and also the encoder. However, the problem still ocured if the ambient temperature in our work shop was high. So we have opened the door of the housing and installed a supplementary fan directly on the vector drive. This was working for some months but now the spindle stutters even at normal room temperature. A electronic technician checked the baldor drive and supposed that a thermo element is making trouble. But without a wiring diagram he is not able to do anything. Fadal Germany can exchange the complete drive for aprox. 6000$. Now we have removed the keyborad an the cover of the baldor and installed a fan dircetly. I supose the problem will increase and we just have spring time with low ambient temperatures. One more detail: If the problem occures the display of the vector drive is clear showing no figures just the background light. Maybe one of you guys had also such a problem or maybe a wiring diagram of the baldor. Thanks for your help.
Buy a new power supply from Baldor
Your power supply in the inverter is flaky. Call baldor and ask for a new one it is easy to put in. Plug and play. Cost less than a $1000.00 U.S. :)
