1 Attachment(s)
Bad corners
Hello
I made a project with vetric. But when I go to 3D View tab and run toolpaths preview it showed me that in some corners my tool will travel too far and these corners will be bad.
Is there something wrong with the set up? Did anyone of you ever experience the same problem? I'm talking about the inside corners
Attachment 212886
Maybe your vectors are open(not joined)???
Mike
I already checked that. And they are joined
Can you post the project file without the center floral design?
1 Attachment(s)
Here you go. I have to make zip file because it won't let me upload .crv file.
1 Attachment(s)
You have 41 open vectors, they may look joined but, Nada. Highlight all the vectors and hit the "J" key. It will tell you how many are open and the resultant number of closed vectors after joining with the specified tolerance. The tool path was starting and stopping at each endpoint. Let me know if that works for you.
Good Luck
Mike
It did!!! Thank You so much. It looks like I need to learn more about functions in VCarve.
