Compare Z axis for new machine
I have been looking around at different z axis and would like to get some input on the differences, capabilites of the selected options. I am open to other suggestion. My goal is to cut aluminum, and I am hoping to be able to cut 2mm per pass. At the moment I am doing about 12 inch/min and would also like to speed that up as well. My goal is the have a nice stiff machine that will be up to that job. I figured I would start with the z axis and work my way backward to find the machine I want.
THK Actuator KR33B Ground ballscrew LM Guide PITCH10MM STROKE240MM NSK CNC Route | eBay
6" Z Axis Linear Motion Table for CNC Router with Ballscrew | eBay
Ballscrew Z Axis | CNCRouterParts
So between the three that I have found.
The first one is a THK and I hear a lot of good things about how good they are. Any thoughts?
The second one looks bigger and I was wondering if this would make things stiffer for the material that I am wanting to cut
The third is the same but 2 - 3x more $$$. Is there a difference that I am not seeing that makes this one so much more. Will it be stiffer, and more suited to the task?
I look farward to any comments or suggestion.
