VFS5 Drive problems - Switch to Vickers Vector drive?
Well my backup Arrow 1000 took a dump while waiting for the X motor to come back on the Arrow 1250C. The "Spindle Drive Not Responding" error came up with the Spindle Drive faulting out when commanded above 300 rpm from a stop. I can run it up to about 1100 rpm if I MDI it up in 100 rpm increments. I ohmed out the resolver and it comes back at 18, 18, and 30 ohms and no shorts between lines so I assume it is not the cable or the resolver.
So looking at the wiring diagram of the Vector drive off of the 1250 and the VFS5 drive off of the 100 it looks like they are nearly identical. The 1250 has the din plug on it for the controller to set parameters so if I program it from the controller to match the VFS5 will this work while I send the VFS5 out for repairs and wait for the 1250 X motor to come back?
Any thoughts?
Re: VFS5 Drive problems - Switch to Vickers Vector drive?
Hi guys this seems to be a very common fault where the PSR stops the spindle from increasing in rpm.
Does it indicate any particular part ie capacitors or thyristor fault. I'm thinking capacitors i have 2 PSR units that are broken and I am hoping to get one of them working.
One has a pretty damming fault where it arcs up across the main DC buss and the other has the above mentioned fault. The DC bus arc unit i have put to one side for now because its in a bit of a mess. I know that the fault is PSR because it came from a mill that also had the same problem.
any advise would be much appreciated
neither; drive circuitry for the input scrs.
no. there are no scrs in the vfs5. only the psr4/5. i meant is it NOT bus caps or scrs themselves.
From what I've encountered, if it was PSU then you should get alarm 39-35 and/or 39-37, sorry I don't have much input but fairly certain your psu is still in working order pmcg.
I think that that alarm is on Acramatic i'm on Heidenhain. I am pretty sure that this symptom of being able to increase the speed bit by bit is down to the PSR. I would really be interested in which part of the PSR causes this failure as there not very complicated.
My understanding is the IGBT in the PSR is only for regen or braking. The thyristors could be faulty maybe they are not turning hard on. The capacitor are there to reduce the ripple from the thyristors switching. What else could it be the controller board?
I have two different versions of the main board b and c. The difference is that the coil resistor is replaced with thermal resistors.
Quote:
Originally Posted by
petesurrey
1) not very complicated.
2)The thyristors could be faulty (mk comment: NOT) maybe they are not turning hard on.
1) YES the SCR turn on circuitry is VERY complicated! Need it be THAT complicated for a soft start circuit? Maybe not, but the facts are the facts. If you understand electronic circuits in minute detail, have enough time to study it, and figure it out (40 hours? 80 hours?) and can do so without putting a dollar value on your time, you can fix it.
2) BINGO. I wish Exedy could be right to simplify your fix, but, alas, he is not.
Thanks Mike I can understand the frustration sorry I didnt mean to oversimplify. The truth of that matter is with a circuit schematic I might have a chance but without one it is as you say 40-80 hrs of studying.
let me add some so folks can understand why this happens....
an induction motor has need for TWO currents, 90 electrical degrees apart. The one IN PHASE with your AC voltage power source input, is called Isq and is responsible for making TORQUE. the one 90 degrees OUT of phase is called Isd, and is responsible for making a MAGNETIC FIELD inside the motor - to make it a motor. A PM motor has magnets to do this so has no need for Isd.
So on YOUR machine, Isd=18amps. Any speed, and torque, it is always 18amps upto base speed rating. It is 90 electrical degrees away from in phase, so you do NOT pay your power company for it - you only pay them for the Isq in phase current.
The vfs5 STILL has to supply it, so it still "counts." run at 100rpm, you will need about .1amp Isq, plus this constant 18amps Isd; put a clamp on ammeter around a motor lead, and you will see about 18 amps.
90 degrees out of phase.... the vector sum of these 2 currents is (Isq^2+Isd^2)^.5 - do the math and you will see your clamp on showing about 18amps.
Cool thing is this 18amps, being FAKE, 90 degrees out of phase, will be supplied by the capacitors in your power supply for free for you - it wont even show up on your 230v ac 3ph input lines to your psr4/5! Only the 1 amp in phase will show up. but even THAT wont show up at directly on your psr4/5 input power leads with the clamp meter!
the whole psr4/5 and vfs5, like ALL PWM drive systems, will pull power from your power company = power out/efficiency.... so assuming 100% for simplicity, (it is around 95%).
Recall how cheap vfd drives work: volts/hz constant curve.... these vector drives do the same basic thing. So if you have a 1500rpm base speed (where you hit 230vac into it), running 150rpm only has 23 volts into it. So put that 1amp Isq torque producing current into it, at 23v, and the current at the PSR4/5 input IS ONLY 0.1 AMPS AT 230V! Piece of cake to run!
Now start increasing your speed.... you can do the math in between, I will just jump to base speed - 1500rpm.... Now we are outputting 1amp at 230v, so the psr4/5 will be pulling the full 1 amp input! That is 10x higher current than the 150rpm's 0.1amp.....
Now, lets go above the 1500rpm base speed.... go to 3000rpm.... it is now constant HP range, we are putting out ALL the voltage we have, 230v, cant go higher, so what happens? WE CANT DO IT! Only way is for us to REDUCE the Isd magnetizing current - the 18 amps has to come down! less magnetic field means field weakening, means to we have to drop to 9amps for double the speed. THAT means the motor Kt is cut in half! Kt=#-ft/amp torque producing Isq. So we only now make 1/2 the torque per amp! So what happens to the amps into the motor? GOTTA DOUBLE! Now, we are putting out 230v AND 2AMPS! So input power is now 2 amps.
Do it again to 6000rpm: Kt has to drop again in half, so current doubles AGAIN to 4amps! Straight through from 230v AC input to PSR4/5....
So see? In summary:
150rpm pulls 0.1 amp from your 230v input to PSR4/5
1500rpm pulls 1 amp
3000rpm pulls 2 amp
6000rpm puls 4 amps
120000rpm pulls 8 amps
Now back to the PSR4/5 input.... Rather than diodes, it uses SCRs so it can softstart. The gate of the SCR must be ramped up to turn the SCR FULL on.
When full on, it acts like a simple diode. When not full on, it is whimpy! It only lets a few amps thru - if that!
So you can see why an SCR input power supply for a VFD will sag and cause you NOT to be able to get to higher speeds.
Now add it MORE amps for TORQUE to ACCELERATE to those higher speeds! Induction motors have a LOT of inertia; At the couple second accel ramps we programmed into the VFS5's for your machine, T=Jw/t - go look it up if you want more details - you will find trying to go up in speed by say 1000rpm will pull like 40 amps! NO WAY on whimpy not turned on SCRs. The bus droops, the drive faults. That is why if you try to go up in speed SLOW like 100rpm at a time, it will make it - until you get to the higher rpms anyway per above Kt reduction chart.
There is my 2 cents.
petesurrey
Exactly! Well put. Unfortunately some companies stance on releasing schematics is strictly verboten.
