How can you bring an existing tool data base built in MS ACCESS in to a Mastercam tool table? Is it possable in Mastercam?
Thanks Nimrod "the mighty hunter before the Lord"
Printable View
Yes it's possible.Quote:
The Access file will have to be formatted correctly for MC to read it.
Once it's formatted properly, go to NC Utils, Define Tools, Library, then right click, and select Create Library from Text.
HTH
'Rekd
p.s., Here's a sample of the formatting, taken from a
library that was converted to text. (The opposite of what you're doing.)
'RekdCode:# TOOL LIBRARY FORMAT - Tue Jun 03 07:38:47 2003
# = comment if 1st character in line
# line 1 - TOOL (start of tool definition)
# line 2 - tool material (1-HSS, 2-CARBIDE, 3-COATED CAR, 4-CERAMIC, 5-BORZON, 10-UNKNOWN)
# line 3 - tool comment
# line 4 - tool name (geometry reference for backplot)
# line 5 - tool manufacturer
# line 6 - chuck designation
# line 7 - tool_no, tool_type, rad_type, dia, crad, thds, tip_angle,
# dia_off, len_off, feed, plunge, retract, rpm, coolant, n_flutes, bottom_turret, station
# line 8 - Drilling attributes (see tool_type in line 7 above)
# line 8 - cycle, peck1, peck2, peck_clr, chip_brk, dwell, shldr_angle, root_dia (tap), bore_shift
# line 8 - Milling attributes (see tool_type in line 7 above)
# line 8 - cut_able, rgh_x, rgh_z, fin_x, fin_z, tip_dia, root_dia (thd mill), thd_angle
# line 9 - pilot_dia, flute_len, oa_len, shldr_len, arbor_dia, hldr_dia, hldr_len, spindle_ccw, sfm, fpt, metric
# line 10 - Holder type, Work offset, Initial dir vector[3], Head offset[3], Tool offset[3]
# (tool types) (tool capabilities) (canned cycles)
# CENTER DRILL 1 ROUGH & FINISH 0 SIMPLE DRILL 0
# SPOT DRILL 2 ROUGH 1 PECK DRILL 1
# DRILL 3 FINISH 2 CHIP DRILL 2
# TAP-RH 4 TAP 3
# TAP-LH 5 (tool corner radius) BORE1 4
# REAMER 6 NONE 0 BORE2 5
# BORING BAR 7 CORNER 1 MISC1 6
# COUNTER BORE 8 FULL 2 MISC2 7
# COUNTER SINK 9
# END MILL FLAT 10 (coolant types)
# END MILL SPHER 11 OFF 0
# CHAMFER MILL 12 FLOOD 1
# FACE MILL 13 MIST 2
# SLOT MILL 14 TOOL 3
# CORNER RAD MILL 15
# DOVETAIL MILL 16 (spindle direction)
# TAPER MILL 17 CW 0
# LOLLIPOP MILL 18 CCW 1
# END MILL BULL 19
# BLOCK DRILL 20
# *** DO NOT REMOVE LINE NUMBERS OR DELETE ENTIRE LINES! ***
# *** ALL TOOL DEFINITIONS MUST CONTAIN 10 LINES AND THE 'TOOL' LABEL! ***
1 - TOOL
2 - 1
3 - 1/8 CENTERDRILL
4 - C:\MCAM91\MILL\TOOLS\CTRDRILL.MC9
5 -
6 -
7 - 1 1 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
8 - 0 0. 0. 20. 10. 0. 90. 0. 0.
9 - 0. 2. 3. 2.5 0.125 2. 1. 0 100. 12. 0
1 - TOOL
2 - 1
3 - 1/4 CENTERDRILL
5 -
6 -
7 - 2 1 0 0.25 0. 0. 90. 0 0 1.0696 1.0696 1.0696 1069 1 2 1 -1
9 - 0. 2. 3. 2.5 0.25 2. 1. 0 100. 25. 0
1 - TOOL
2 - 1
3 - 1/2 CENTERDRILL
5 -
6 -
7 - 3 1 0 0.5 0. 0. 90. 0 0 1.0696 1.0696 1.0696 534 1 2 1 -1
9 - 0. 2. 3. 2.5 0.5 2. 1. 0 100. 50. 0
1 - TOOL
2 - 1
3 - 1/8 SPOTDRILL
4 - C:\MCAM91\MILL\TOOLS\SPOTDRIL.MC9
5 -
6 -
7 - 4 2 0 0.125 0. 0. 90. 0 0 1.026816 1.026816 1.026816 2139 1 2 1 -1
thanks Rekd I have to see now if I can get my MSACCESS tool table format to come out like that.
You're welcome.
If you need a hand with Access, and I have the time, I'd be glad to help.
'Rekd
