Originally Posted by UKRobotics
Do you know if mach has an option to automatically reverse off a limit once hit or does it always have to be done manually. If the former is true then it would make sense to have separate inputs for + and - otherwise i might was well stick +, - and home all on one pin.
I have already considered another parrallel port card but even with that I worry about running out of inputs and outputs. In addition to the limit switches I also need inputs and outputs for charge pump, VDF, spindle reverse, estop, x,y,z,a axis motor encoders, x,y,x,a step/dir, an MPG, switches to jog each axis, power drawbar, ATC, suds pump, auto lube system, lights, vacuum table and no doubt more things I havent thought of.
