I was playing around with my path pilot today. Thread milled a hole and the threads were left hand. I don't see anywhere to change to right handed threads.
Printable View
If you were using the conversational page to program the thread mill, and you haven't upgraded to V1.6, you may want to. It lists the left hand instead of right hand threads as a bug fix.
Direct Document and Software Download | Tormach Inc. providers of personal small CNC machines, CNC tooling, and many more CNC items.
Adam
Just change G02 to G03, or vise-versa.
I had the same problem the first time I cut an inside thread. I must have reprogrammed that thread a dozen times before it hit me like someone hit me with a baseball bat.
START AT THE BOTTOM AND THREAD UP.
Installed v 1.6 the threading appears to work normally. I did learn that the machine needs to be out of e-stop to choose internal or external threads in the conversational tab. I also noticed that the z dro does not change while the machine is running (the real z is actually moving normally).
I did thread milling on PP v1.6 the other day and starting at the top and going down worked just fine.
Whether you go top-down or bottom-up is a function of both whether you're cutting LH or RH threads, and whether you're climb or conventional milling.
Thread Milling Direction
RH Climb Bottom-Up
RH Conv. Top-Down
LH Climb Top-Down
LH Conv. Bottom-Up
When thread-milling, climb milling is strongly preferred.
Regards,
Ray L.
Was that only while you were thread milling or all the time? Did you feed that back into Tormach's Beta Bug reporting database?
http://www.tormach.com/pathpilot_tracking.html
Did you not bother to actually read what I wrote before responding? And conventional milling is hardly "just pushing material out of the way". It cuts, and makes chips, just like climb milling, the only difference being the chip is thicker at the end of the cut than at the beginning, while climb milling is exactly the opposite.
Regards,
Ray L.
All of the conversational programs appear to climb mill by default, without the option to conventional mill.
