Re: 6040z 4-axis Router Help
Do you only need help with the A axis or all axes? -- it isn't quite clear from your original post.
what model, what brackout board is the ESS connected to, what are all the pins used ??? just more info required for you to get help
1 Attachment(s)
Attachment 277142 pls help very arugent to 4 axis post wrong a axis more than 360 this the only problem
dude start your own thread
Give me a few hours, and I will upload pictures of everything.
2 Attachment(s)
Quote:
Originally Posted by
daniellyall
Let me make it more clear for you. :)
1. I have the ethernet cable connected, along with the usb 5v power, and on the back of the control box it's connected with a parallel port.
2. Mach3 IP Config is set up and it recognizes it in Mach3, but since the PINS etc aren't configured properly it won't move the machine (That's my assumption at least)
I need help with as many of the axes that I can. I'm trying to be careful as not to set the wrong PINs in the wrong places, just incase it might mess something up.
While talking to CNC they said it shouldn't be necessary for a breakout board, but if that's not the case I would like to know. (If I can get it to work at least somewhat, I can work with that until I buy a G540 or something.)
Quote:
- CNC 6040 4 Axis Router is designed for large area engraving work .
- Simple operation and installation.
- Emergency stop button enhance security,Large 3D engraving in soft wood,MDF board,native wood,PVC.
- Cover plates reducing pollution for the screws and shafts.Thick 15mm aluminum 6063 plate.
- The NEW 0.8KW water-cooled VFD spindle is available operating for long time.Controlled by computer
Technical Parameters:
1.Max.thickness of the meterials:100mm(the distance between Z axis and the bottom of the working station)
2.Work table dimension:750mm x 450mm
3.Carving speed:0 to 2500mm per min
4.Frame materials:6061 aluminum alloy and 6063 Industrial aluminum
5.Resetting accuracy:0.05mm
6.Engraving accuracy:better than 0.04mm(has been tested)
7.Stepping motor type:57 two-phase 3A ,super-low noise
Features:
1.Mach 3 software is simple and intellgent.
2.With 0.8KW water-cooled VFD spindle and 1.5KW inverter.
3.With four axis(rotary axis) and tailstock
4.Stepping motor knob is useful for small positioning adjustment ,with steady and strong support structure.
5.The 0.8KW water-cooled VFD spindle is available operating for long time,which can reinforced the processing abilty of the machine and can be used to process aluminum alloy and hard wood.
ArkSeyonet
so you have the bob conected to the ESS in port 1 of the ESS
correct
the ESS needs connected to a breakout board (bob) so you have the computer connected to the ESS then the ESS connected to a bob the black box in pick
you still need to supply info on bob, ports and pins or a manual that came with the machine
1 Attachment(s)
daniellyall
(Most of the instruction manual was in Chinese, which made it difficult for me to set it up properly.
For anyone having this specific issue with this exact setup.
Windows 8 or 8.1 64-bit, using ESS with the same router and control box.
1) When you install the ESS and hook it up via Ethernet, make sure you go into your LAN properties and set ipv4 to IP Address: 10.9.9.1 Subnet: 255.255.255.255
2) Then when you install the plugin into Mach3, you can set the address anywhere from 10.9.9.2 to 10.9.9.9 but it must have the same numbers in the first three locations.
3) The ports for this that made it where I could move the motor properly is in the image attached.
IN THE OUTPUT SIGNALS DIGIT TRIG IS Active but I can't remember what it wanted the setting to be as I'm not near the machine right now.
Thank you to everyone that wished to help. :) It's much appreciated.
so have you got it working
2 Attachment(s)
plsAttachment 277380Attachment 277382 heip in mastercam rotary 4 axis subsitiution unroll can not work why
