Robodrill T10-a Alarm 911
Hi Guys, I Hope Somebody Could Help Me, I Have A Robodrill T10-a
Whit A Fanuc 16ma Control.
Recently Becomes To Show The 911 4n+1 Alarm, At The Power On.
So, We Call A Mexican Fanuc Reseler, And He Comes To Check It, So After Some Testing, He Says We Must Buy The Main Cpu Board, So A Few Days Ago We Install The New Cpu Board, Whit The Old Modules (like Pcm, Ram, Control,etc) And The 911 4n+1 Alarm
Its Still Present.
So, We Have Another Robodrill In Good Shape Working, So We Took The Main Board From The Working Robodrill And Put It Into The Damage Robodrill And It Works!
Next Test Was To Change The Good Modules From The Working Main Board, Into The New Main Board And Put Into The Damage Robodrill, So....result= 911 4n+2 Alarm
In Both Tests We Reset The Memory Whit The 'delete' Key At The Power On Shutting, And Nothing Happens
Now, The Fanuc Represent Seller Can't Come Right Now, And I Have A Lot Of Job To Do, So Anybody Can Help Me?
Re: Robodrill High Amp Draw
Quote:
Originally Posted by
Kenintrouble
jderou,
It has been requested of fanuc to either replace or repair this machine. Fanuc has responded with a number of suggestions for repair. Because of the time of year, its going to be difficult to follow thru in a timely maner, but we are working on it.
If they will replace the machine or not remains to be seen. I'll keep you appraised as time goes by.
Ken
Hello we have a Chevalier 1620 with a oimf control and ours is doing the exact same thing. We have changed the drive and still no luck. Did you ever find the problem?
Does anyone on the forum know this guy that had the trouble? Im experiencing the same issue and fanuc cannot find the problem. I wish i could get a hold of ken...
