Holding down Styrene sheets
Plastic experts help needed.
I have a DIY FLA CNC machine and works well. I made a vacuum box from MDF and sealed all sides but the top. Using a shop vac to suck vacuum. It seems to hold down my Styrene sheets (0.040') but when cutting the parts I loose vacuum. My question is what would you recommend to hold down the sheets as the vacuum system does not seem to work. I am using a upcut bit. Afraid that when using a downcut I get chips under the sheet and then also lift the sheet.
Would love to hear from all of you!
Thank you!
Re: Holding down Styrene sheets
I doubt your shop vac is strong enough to provide vacuum pressure sufficient to hold down your parts; it's good for cleaning up chips, though. Look for a real high-volume low-pressure vacuum pump. Usually these are single-stage rotary vane type pumps. Size it to be in scale with the size of your vacuum pod.
Thank you very much for your reply.
What would you consider a good size pump. My box is 20"x24"
That is an other great idea. Thanks beone
If your wanting to do this cheaply..... what 1 shopvac wont hold down 2 or 4 might hold down. I think there is even someone out there that sells a setup with 4 vacuum/shopvac motors for this purpose.
