ATC Bt30 7.5kw 380v spindle/220v 1 phase vfd availability
I've been looking at a Chinese ATC BT30 spindle (model GDL125-30-18z/7.5). The spec sheet online refers to it as 220v/380v. Another spec sheets refers to it as 380v only. Will this spindle operate on 220v 3 phase, or is it 380v 3 phase only? If 380v only, can I get a VFD that takes 220v 1 phase input and has 380v 3 phase 600hz output? While I see multiple 220v 1 phase input vfds on the internet with 220v 3 phase output, I have only seen one 220v 1 phase input with 380v output VFD. This makes me a bit leery that I can get a 220v 1 phase -> 380v 3phase (600hz) VFD. Are there other options to make this spindle work with on power originating on 220v 1 phase?
Any guidance would be greatly appreciated.
Re: ATC Bt30 7.5kw 380v spindle/220v 1 phase vfd availability
Quote:
Originally Posted by
Arjay
So back in contact with the Chinese mfg and they tell me they offer the 380v spindle in a 220v configuration. I need to confirm the same price and other specs, but this sounds like the way to go.
That's a bit confusing, I guess I would ask if it's 220V or 380V. Maybe it looses something in the translation. :)
most vfds only produce up to 400hz output, others are limited to 200hz, or 120hz.
a 600hz vfd will drive a 2 pole spindle at up to 36000 rpm and a 10 hp spindle at that speed is fairly specialized and you should buy the vfd from the spindle manufacturer so as to preserve the warranty.
if you want to do this cheaply for some reason, then just buy a 220v to 400 volt 3 phase transformer and use an rpc to generate your 220vac 3 phase from 220vac single phase. run the vfd off the 400volts 3 phase to drive the spindle.
you cannot insert the transformer after the vfd for a number of reasons.
at 600hz there is a ridiculous amount eddy current and hysteresis, you may not be really buying a 10hp spindle. more like 5hp and the other 5 hp goes into heating it up at such operating speeds under full load. peak torque might be 300hz and less than half the voltage, but perhaps even more current.
anyhow, so it appears the 220/380v is just changing the wiring from wye to delta.
in any case, you're proposing to spend 2300 usd on a 31 kilogram spindle. i suggest you ask for second opinions on the practical machinist forum.
and finding a 600hz VFD might cost you as much money as the spindle.
Arjay
I think maybe I've lost something in the translation in my post here. :) Originally the model was listed in some spec sheets on the internet as 220v/380v (300hz/600hz); however in nailing down the price with the sales rep, I was given a spec sheet that only showed 380v (600hz). After posting my original question here, I emailed the rep that I need 220v. She said she needed to ask their engineer and got back to me later saying the engineer said they could make it in 220v. I have asked for the spec sheet for the 220v model.
[Edit] The sales rep has gotten back to me and the price is the same at $2300 and the engineer will send the spec sheet.
$2300 for an ATC BT30 7.5kw spindle motor seems reasonable from what I can tell.
If anyone sees any red flags (I am going through alibaba dot com), please let me know.
Last question... The rep stated that this 220v model will be 600hz - will I have any trouble finding a 220v 7.5kw VFD that supports 600hz?
tia
Most of the VFD drives for 600Hz are for 380v 7,5Kw the 7.5Kw is the problem for a 240v 600Hz VFD , there are Drives that are 240v 600Hz for lower Kw spindles
Your best if you are planning to run on 240v single phase, would be a Phase-Perfect, and a step up Transformer to the 380v VFD, a RPC is inefficient, a Phase-Perfect costs a lot more but the extra cost to run a RPC the Phase-Perfect soon makes it's extra cost not an issue
Elddon _Joh it is quite common to have a VFD with 600Hz and even 1000Hz 10HP 7.5KW VFD Inverter 3ph 380V 1000Hz 18A Variable Frequency Driver Controller | eBay
Delta Inverter VFD Drive VFD075E23A 3Phase 220V 7.5KW Frequency Converter New | eBay
Hey Arjay. I've just started going down a similar path but am opting to use a 3KW atc 220v spindle for wood working. I was wondering what you settled on. I've also read some confusing issues with BT30 tool holder balancing and wondering what your experience might be especially up in the 15k rpm and higher range if you are cutting there. Thanks
