Low Current output to Laser Tube
Hello all,
I have an issue with my Laser machine, I am working with Ben and Nolan from Thunderlaser to solve my issue but thought I would see if anyone else has had a similar issue:
Mars 90 100W CO2 laser machine
Problem:
Does not cut materials as used to, ie used to be able to cut up to 1/2 wood with relative ease. Now will not cut 5.2mm plywood. Using the material settings for 12mm MDF in RDworks I cannot cut 5.2mm plywood. I have replaced the Laser tube, same result. Read the amps to laser tube ~4-5 mA at 60% setting, should be ~28mA. Replaced the Power supply, still the same result. I hope someone has some ideas.
Re: Low Current output to Laser Tube
Just a thought - have you cleaned and made good the high voltage and low voltage connections on the tube??
I have found that on one of my lasers if the min power setting is set below the max setting my laser will only cut at the low setting even if I tell it to cut a 90%
