Fanuc series 10 programming
Hello, I am new to the world of cnc and I just got a nakamura superturn 2 with a Fanuc 10TE-F controller. I do not have the programming manual and I would like to know how to use my lathe. Would it be possible to have the programming manual or help to build one.
Re: Fanuc series 10 programming
I need help or at least a good start.
Do you know how to set it up, touching off tooling etc. ? does this control have FAPT?
Basic programming codes are same on all Fanuc machines. Set-up method would be a little different. For learning programming, grab any programming book to start with.
Well then sinha_nsit reply is a good starting point, imo Fapt is great for lathes, it will generate the g code for you.
