1 Attachment(s)
Chinese USB 3020 Limit Switches
Have been searching the vaults on the forum but drawn a bit of a blank. I recently purchased a China 3020 CNC router and want to fit limit switches to it, the board is a JP-382C . My hunch is is the white socket arrowed in the picture is where I need to connect the positive feed wires to the axis switches. So is there anyone here who can advise me further please?
Attachment 375418
Re: Chinese USB 3020 Limit Switches
Mr. Sprue,
You are correct, that is the limit switch connection point X Y Z and G=ground.
Pins 11, 12, and 13 are the outputs of X,Y and Z.
Jeff...
Hi Jeff... Many thanks m8 for you reply, you are an absolute star.
One more question please: the fourth axis I take it there is no limit switch for that is there?
Cheers
Dave
Dave,
You could also wire all normally closed switches for all axis in series and use one limit switch connection. Assign all limit switches to the same pin in Mach3.
Presto done!
Jeff...
Quote:
Originally Posted by
Mr Sprue
Cheers
Dave
Furthermore can I ask one more question please? How did you know the pin numbers?!!!!
Thanks again for your advice Jeff your a saint!
No worries,
Mr Sprue
Previously I helped someone who had the identical PCB board and we used a ohm meter to determine which pins are routed to the X Y Z respectively.
Have a most awesome weekend!
Jeff...
1 Attachment(s)
Hi again Jeff
Managed to source all the components yesterday that I should need to fit the switches. But before I crack on I would like to ask for your valued advise once again please. Firstly would the (X Y Z G) socket on that PCB have the home position switches wired as (NO) or (NC)?
Secondly I think in addition to the home switches it would be sensible to fit additional axis limit switches, from what I have seen on the web, limit switches can be wired in series from the emergency stop button.
Although this image I've found below does not represent my PCB it does provide the schematic layout of which I am asking advice for. What do you think?
Attachment 375524
Mr. Sprue,
(NC) normally closed switches are preferred for several reasons.
The diagram you posted is not correct, it shows the limit switches in parallel they should be wired in series.
Jeff...
I am wiring the same basic machine as you ..worked on it today got the plug to the board wired to plugs on the back of the control box and got x limits done and working ... with the board they give you it will have to be wired normally open .. I wired in two micro switches left / right limit to the board and am planning on the same for Y ... the odd thing on my board was X was pin 12 when I set it up ..
jalessi
Mr. Sprue,
[FONT="](NC) normally closed [/FONT]switches are preferred for several reasons.
Jeff...
Hi Jeff for some reason I was under the impression that the "Home" limit switches had to be on a separate circuit to the other 3 limit switches which are installed to prevent a crash. If I follow you correctly are you saying that all six switches are wired from the "X Y Z G" socket in series? That would mean not using the emergency stop circuit.
Regards
Dave
caddycarlo
Hi Caddycarlo Do you a wiring diagram of what you have done please?
So wiring the two switches in a parallel circuit works then, and that the controller does not need two separate circuits to determine which side of the axis the spindle has travelled to ?
I take it the "G" (ground) is a common to use for all switches.
jalessi
No worries,
Jeff...
I have been googling for this for a few days now. I have the same board as the OP JP-382c on a 3040 chinese CNC. It has both USB and parallel ports. I appreciate the pinouts for the limit switches as I'm wanting to add some soon. I have yet to get this board working with Mach3 though. Using a Pentium 4 laptop (being a laptop maybe the problem. Maybe not enough voltage?) which has a parallel port and running Windows XP 32-bit. I get nothing from my mill when using Mach3. I just ordered a mini ITX motherboard that has a parallel port to build into a small computer in case the laptop is the issue. Would you provide the proper pinouts to setup Mach3 for this board if you have them? Or any information you can? Thank you.
Manny,
Check your P.M. Mail
Welcome to the Zone,
Jeff...
OverlordManny
You guys are true heroes.
