Can you export FROM Alphacam
So my company is a little screwed up and we use 3 different programs. I work in the metal part of the shop mostly cutting metal panels using a program called Panelbuilder, and I use VCarve Pro for anything that isn't a panel. Now the wood shop uses alphacam for everything they do. Well they need me to take there alphacam drawing and make there stuff on our machine. Now I don't know anything about alphacam, but can you export from alphcam to autocad. then I can import it to vcarve to make my life easy
Re: Can you export FROM Alphacam
Use the "Output Cad" option in the "Home" tab of later versions of AlphaCam ( can't recall where it is in earlier versions ), select "File Type" usually DXF for 2D or IGES, STL, Rhino for 3D.
Regards,
