Hi guys. Im a newbie to all these. I got myself a chinese CNC 3040Z-DQ machine. Assembled the machine and everything works fine. Learned how to draw 3D objects and creating tool paths. When I tried the first engraving, 1 of the gcode was wrong and lead to the spindle plunge all the way down. Jammed then stopped. I stopped the Mach3 right away. Removed the drill bit from the wood and the spindle wont run again. X Y Z still works controlled by my laptop. Just the spindle doesnt workor spins anymore. Checked the cables connects to the spindle with a DC voltage of only 0.4 Vdc. The controller machine is on and connected to mach3. I disassembled the spindle and everything seemed fine in the inside. Anyone can shed me some lights whether its the spindle or the controller having problem? Or where should I check inorder to know what should I get for replacement or get it repaired?
Thanks in advance!
http://www.cnczone.com/forums/attach...d=377706&stc=1http://www.cnczone.com/forums/attach...d=377708&stc=1
