C10 BOB limit switch wiring
Hi. I'm fairly new to cnc world. I am building my own cnc router machine. I'm currently trying to wire up limit switches to the c10 BOB. I have NO/NC switches and I don't know if I require the use of a resistor or is there a resistor on the BOB. again, I'm a noob. Thanks
Sent from my SM-N900W8 using Tapatalk
Re: C10 BOB limit switch wiring
If your input voltage is 5 volt or 0 volt you can connect it
without any resistor directly.
what is your software ?
you can contact me
[email protected]
The c10 BOB has 5v for the switches. I'll be running mach 3.
3 Attachment(s)
which version of the C10 breakout board do you have ?
a while ago I reverse engineered the C10 BOB from various photos on the net to produce this diagram
Attachment 381238
Attachment 381246
on the C10 a jumper connects the 5 input terminals via a 4K7 resistors to either +5V or ground
(so they act as either pull up resistors to +5V or pull down resistors to ground /0V)
with your limit switches connected between GND and the input terminals you need to put the jumper on +5V
its usually safer to connect the switches as N/C so a broken limit switch wire stops the machine
several switches can be wired in series so you only use one input terminal if you need to save the other four inputs for other uses ( E-stop , touch probe and MPG A&B outputs for example )
If you have conflicting requirements for pull up or pull down resistors by having switches that ground four of the inputs and one that connects an input to +5V
you can connect the C10 jumper to +5V so the on board 4K7 resistors act as pull up resistors on all inputs
then for the input with the switch to +5V you can connect a resistor of about 200 to 500 ohms between the input and ground
this low value of pull down resistor will over ride the effect of the on board 4K7 pull up resistor
John
note
if you have the C10S it uses one 74ACT245 to buffer printer port pins 2 to 9 instead of the two 74ACT245 IC's on the earlier C10
Attachment 381248
The c10 BOB I have is revision 10.3. I plan to use two limit switches per axis. I guess the two the two limit switches per axis will be in series. So its best to wire limit switch to NC and have jumper set to 5v to pull up? I appreciate all the help so far.
yes
on each axis wire the two N/C limit switches in series and set the input resistors as pull up (to +5V)
John
Perfect! Thanks for the help. Another question I have is can the c10 BOB trigger the router to turn on when the job begins and off when it's done?
yes depending on what router spindle you have
if its basically an AC motor with a collet chuck ( like a Dremel with the switch locked on)
you can use one of the possible twelve C10 outputs to switch the spindle on &off
either using some thing like cnc4ps's C37 - Single Relay Board / C15 - DUAL RELAY BOARD
or a solid state relay
if you want to control a VFD drive & 3 phase spindle motor you will need to add something like cnc4pc's
C41 - PWM Variable Speed Control Board
John
