Adv. Posting auger on/off
Trying to have advanced posting tab with the ability to turn chip auger on or off for pocketing routine
Can get the tab to show up in the wizard,but posting does not acknowledge it
So I figure something on line 3 or 2001 is wrong
any help appreciated
3. Tool change
n,spindle_off
n,"M09"
n,program_block_1
n,rapid_move,incremental_coord,"G28","Z0."
n,optional_stop
"(NEXT CUT - NEXT TOOL)"
system_comment
feature_name_comment
n,t,"M06"
n,rapid_move,absolute_coord,work_coord,force_x,xr, force_y,yr,rotary_xyr_angle,,s,spindle_on
n,rapid_move,length_offset,coolant_on
output_rotary_angle
2001. Program Block 1 - Output code M33 or M31
code = MILL_GetUserSelectComboVariable(0) 'Get which item is selected for COMBO_BOX 1
'0 = M33, 1 = M31
'ans = MsgBox("code is " & code) 'Display message box with value of code
Select Case code 'Output the correct string based on user selection
Case 0
MILL_SetReturnString(" M31”)
Case 1
MILL_SetReturnString(" M33”)
End Select
Re: Adv. Posting auger on/off
here is the custom file to put the tab in the wizard
COMBO_BOX,1,M33,M31
TEXT_LABEL,1,Set Auger Mode M33 off
DEFAULT_COMBO_INDEX,2,3
Well,we lost SBC a while back to M Cam,,,he bought a 5 axis Haas that came with it I believe,,,anyhow,huge lost to the forum
General,do you see something that looks wrong ?
Quote:
Originally Posted by
jrmach
I agree, great loss to the community :(
Anyway, what I have works here although all I could see was the last line of the custom file, so try out the following and if it works for you as well then great if not back to the headache pills :D
Program block setup is :-
2001. Program Block 1 - Output a M31 or M33 depending on what is selected in the posting page
code = MILL_GetUserSelectComboVariable(0) 'Get which item is selected for COMBO_BOX 1 '0 = M31, 1 = M33
Select Case code 'Ouput the correct string based on user selection
Case 0
MILL_SetReturnString(" M31")
Case 1
MILL_SetReturnString(" M33")
End Select
Custom file is :-
COMBO_BOX,1,M31,M33
DEFAULT_COMBO_INDEX,1,1
TEXT_LABEL,1,Select Auger M33 Off
Like I said, works here, hope it helps :D :D :D :D
Regards
Rob
headache pills,,need a new prescription
just does not want to output a M31 or M33
jrmach
What are you saving the Combo Box file out as into your Post Processor Library ??
It needs to be like this :-
Your PP name followed by the extension .CustomPocket, example jrmachHAAS.MillPst.CustomPocket
If you wanted something to have an Advanced Post page on a Profile operation then the .CustomPocket would be a separate Combo Box file of .CustomProfile.
Hope that helps a bit, I`m pretty rusty on this stuff, must be around 4/5 years since I played around with it :D :D :D
Regards
Rob
1 Attachment(s)
jrmach
Just for your information, I have managed to do it with a "shared" Custom file and if it helps you any here are all the files that work together, the BobCAD Pocket file with Profile finish, the Advanced Post Processor and the Custom milling file. The Pocket file was done in V28 Build 2067, let me know if you have an earlier version/build and I will do a BobCAD file in V26 for you, it all outputs fine here so I don`t see any reason why it wouldn`t work at your end :D :D :D
Have fun :) :)
Regards
Rob
1 Attachment(s)
Rob,,,when I put everything in my PP,,it don't work
Perhaps you could look at my PP and try it ?
This is a untouched copy of my PP
James
It looks like your PP is not an advanced posting engine one, I am working on a duplicate of your PP that works and has all the tweaks etc :D :D :D
Could be a couple of hours or more depending on what/how many changes I will need to make :( :(
Regards
Rob
1 Attachment(s)
James
Phew, don`t want to have to do that too many times :D
Attached is a modifed version of your original PP, I assume that it does work for your HAAS machine, if so then it should continue to do so but please, please double check all your code for at least the first few jobs you do, I have been doing lots and lots of typing and it is very easy to do a little "typo" here and there :D
I have slightly altered the name of the PP and the CustomMilling file so that it shouldn`t interfere with any of your existing files in your PP library, you should just be able to copy and paste into the Library and then in your job select the new PP as the default PP :D
Hope this works for you this time, I have done 3 different Combo Boxes in the CustomMilling file so you can see how the numbers (Particularly the Index ones) are laid out, all you need to do is place the call out line where you want it in the PP, I have left all 3 in there so just do a simple pocket with a profile finish and have a play changing the selections around to get the hang of it all :D :D :D
Because it is a "Shared" CustomMillling file it will be available on all 2 axis through 4 axis features so it may require some careful positioning of the call up lines to avoid things being called up where they are not wanted:D
If you only want the single M31/M33 option then you can easily change the CustomMilling file to a CustomPocket file just by doing a re-name :D :D :D
Fingers crossed, enjoy :D :D :D
Regards
Rob
TY
At least it showed up in code
Not sure about turning off when I want
after a few real life jobs I'LL know
wtf,,,,my PP is ancient?
"It looks like your PP is not an advanced posting engine one"
no idea what you talking about
jrmach
TY
Glad it`s working for you, all`s well that ends well :) :) :)
Don`t know if your PP is old, it does seem to be a bit jumbled up but it does work so "ain`t broke so don`t fix it", the PP that I modified for you is an old V26 one that was known to work with the Advanced Posting so that is why I used it, originally uploaded by Al :D
No all PPs will accept the advanced posting, I have no idea why, something embedded in them I would expect ? ? ?
Regards
Rob
Just to be clear,,the very last PP that you got to work was mine that I uploaded,,correct ?
or
it is a modified V26 ?
jrmach
or
Modified V26 with all the stuff from your PP added to it to bring it up to the same as the one you uploaded and with the ability to do the Advance Posting so it will work exactly as your PP did plus what you wanted :D :D :D
gotcha,,,,
you come Stateside,Idaho to be specific,,,dinner on me Rob
jrmach
gotcha,,,,
If I ever get over there I will certainly take up your offer, just as long as there is a nice baked potato with the steak :D :D :D
Looked Idaho up, looks like a great place to live, all that clean,fresh air, lucky guy :D
Regards
Rob
you can have Lobster too,,,I really appreciate your time
1 Attachment(s)
Hey guys! I poke my head in every now and then but I don't get near the time I once had to participate. I assure you the loss is mine and I very much miss this forum and the old BCC forum. I could write encyclopedias with the knowledge milked from all of you ;) I also still use BobCAD (V29) despite having MC. I still make a lot of the same parts (or revisions of them) that I've been making with BobCAD for over 10 years now. Every new version gets better and I find ways to save time on old files all the time. And it's much faster to program a revision with BobCAD than start all over in MC. I'm running these parts today - programmed in V26 - and I managed to shave 3 minutes off the final operation with some V29 enhancements and tweaks.
It's funny that I ran into this thread today because I was thinking of this exact problem a few days ago when I reprogrammed this part. I made multiple tweaks and I had to keep adding the M31 code manually each time to move the plastic shavings (they pile up fast). I remember jrmach made a thread on this some time ago but I wasn't able to follow up. Now I need it and here it is! This community continues to be a valuable asset and you guys have always been a part of it as long as I have been here. I am blessed to be a part of it! Nice work Rob, I'm going to hack this into my post and I will upload the result if I get it working, thank you!
jrmach, I think you were right there and I think I might see the problem. I'll look at your post as well for my own sake, I'm rusty on the VBScript and was never that great with it to begin with :D I'm glad to see you are all still well and active and I would love a meetup with all of you, we'll have to fight it out on who is buying beers and dinner :)
1 Attachment(s)
Hi SBC,,,
I bet you do get quite a mess with those parts
nice to have the adv. post instead of either letting the auger run all the time/or having to edit it in the program/or babysit the machine and turn it on and off at will
not a fan of wearing out something like a motor when it don't need to be running,,,on the same token not a fan of clogging up the coolant drain
We don't need to fight over who buys drinks and dinner,,,I'll buy but,you guys leave the tip
I especially wanted to solve this riddle with advanced post with the upcoming part I got.It is a repeat job,,,and chips are flyin at times
Note in picture a quarter///this part is pretty big compared to what I usually do
Sure wish I had a bigger lathe to do part of that job
Also the optional stop is a bonus,as I have many parts I need to release vise and re-clamp after roughing and before finishing to tame the warp
