8 Attachment(s)
DIY Marble - Metal Machining 3 axis CNC Router
Greetings gentleman,
Here I would like to post my new welded construction 3 axis cnc router design.
X axis : 3.000 mm
Y axis : 2.200 mm
Z axis : 600 mm
It is now on design stage.
Material to be machined will be marble and carbon steels.
First post will be about Bridge - Saddle - Ram Design.
At first i started with one linear rail on each side of bridge (X axis) and one ball screw.
Afterwards I increased the linear rails on each side to 2 in second and thirth designs.
Difference between second and thirth design is,linear carriage mounted bridge supports on each side is 300 mm for second 200 mm for thirth.
Center distances of linear carriages is 170 mm for both second and thirth design.
Total 3 designs. I would like to hear what is your choosing among 3.
Linear rails are roller bearing type for higher load capacity.
Linear guide rail Size : 35 mm
Quantity on right side : 2
Quantitiy on left side : 2
Ball screw size : 40x8 mm
For Y axis 3 linear guides . One of the linear guide rail is located on top with a different direction.
This will improve the strength of the bridge %20 higher according to studies.
Linear guid rail size : 35 mm.
Ball screw size : 32x5 mm
For Z axis; there are 4 linear guide rails. 2 at rear 2 at sides.
Linear guide rail size : 28 mm
Ball Screw Size : 32x4 mm (may be this size will get smaller)
Mass :
Ram : 240 kg Saddle : 240 kg Bridge : 1.200 kg Bed Frame : 4.800 kg
Y and Z axiss will have 1 kW servo motor - 3000 rpm drive, directly assembled to ball screw via coupling.
X axiss will have 2 piece of 1 kW servo motor directly assembled to ball screw.
5 Attachment(s)
Re: DIY Marble - Metal Machining 3 axis CNC Router
There will be 2 counter weight pneumatic or hydraulic cylinders located on Z axis saddle for balancing the Z axis Ram.
This will improve Z axis servo performance.
2 Attachment(s)
You may see rail lock and carriage lock units at every axis.
2 Attachment(s)
Here are self leveling chocks and my standard leveling blocks for bed frame.
Very nice. Double or triple linear rails on one axis require very high mounting precision .
On your Y axis i would move the ball screw lower, to be "closer" to the tool.
Spindle -1ES793 - H6161H1060
Spindle -2
ES796 - H6161H0916
I think i will choose spindle-2 due to connection flange location. I can use 1 bolted plate to bottom of ram.
There fore it will be easier.
Is there any specific requirement to cut marble ? So you need a big spindle and expensive one ...
Good solid designs. Are you planning on using water with the diamond tools?
I also don't quite understand the purpose of the middle rail on the Y. It doesn't seem to contribute much, as it's near the axis the carriage would want to rotate on.
Any reason for doubling up rails on the X rather than going with larger rails?
Similar concern on the Z, getting those outside rails aligned properly is not going to be easy.
