oky my spindle has the 1/4" shank will not let me put a 1/2" shank in to use for cutting.... plz some one help me ..
Printable View
The reason it only accepts 1/4" tools is probably because it doesn't have enough torque for 1/2" ones. If you need to run 1/2" diameter tooling, get a bigger spindle.
oky ty sir
i have this cheapo
CNC Spindle Motor 400W ER11 & Mach3 PWM Speed Controller + Mount Engraving Kit would like to put bigger size bits in other than a 1/4 .....and my machine is the openbuild ox from mark crew but i extended it to 1500 x 1500...Attachment 395164
You need a ER20: you can use 1/16", 3/32", 1/8", 3/16", 7/32", 1/4", 5/16", 11/32", 3/8", 13/32", 7/16", 1/2"
thats why i want the ER20 so i can put different size bits in and some one told me that will be to heavy i was looking into one looking for options looking at hitachi routor
https://www.ebay.com/itm/Hitachi-M12...4AAOSw8K5aubRz it dose the 1/4" to 1/2" bit sizes weight is like 7.5 lbs
