Help: Fanuc Servo Battery 6V Dead
Hello Friends
I use CNC Lathe machine Fanuc control 0imat-TF but unfortunately servo battery goes to dead. i replaced the battery but parameters are lost and the f
following alarms are occurred.
DS 0300 X axis need Ref return
DS 0300 Z axis need Ref return
Please anybody solve this problem.
Re: Help: Fanuc Servo Battery 6V Dead
If your machine is showing this alarm it has not lost its parameters it just needs re-referencing
What machine is it
Please anybody solve this problem.[/QUOTE]
I take it you mean the reference switch on the controller
That is a red herring as machine needs to be calibrated to obtain a position from its zero
What controller is it ? and what machine
- - - Updated - - -
Quote:
Originally Posted by
brujo
Hello,
I have a similar problem. I read a "1390 turret amp alarm" on a hwacheon lathe control FANUC 18T. I changed the battery. How do I re-reference my turret?
look in parameters does it see the turret as an axis ?
Sorry about the late response.
The machine is a Hwacheon Hi-ECO 21HS BB, the control is a FANUC 18T. The alarm displayed on the control is "1390 TURRET AMP ALARM" and on the servo amplifier (a06b-6093-h152) I get the "II" or 11 alarm.
The 1390 alarm, according to what I could find online, means "TURRET TEST MODE".
And the 11 or "II" alarm on the servoamp means: "When the absolute pulse encoder is used, the motor has not yet rotated through more than one turn after the first power up"
My problem is that I cannot figure out how to rotate the turret!!
Here is what I have tried so far:
1- I enable WRITE MODE (change from 0 to 1)
2- I go to the keep relay page and according to the manual:
K0.0 set to 1= TURRET INDEX AT ZERO POSITION
K0.1 set to 1= TURRET 1 POINT INDEXIONG MANUAL MODE
(I have tried turning each one independently and combined)
3- I go back to WRITE enable mode and turn back to "0"
4- Press reset
I should be able to uncamp the turret, the problem is HOW. And that is where I am stucked
