Hello,
After loaded step or igs file into CAM module, I can't do anything with model.
Why can't I work with step or igs files in CAM module?
Best Regards
Amnon
Printable View
Hello,
Best Regards
Amnon
We need more information about what is happening. When you say you can't work with the model, what is the problem?
Try doing a Wave link from the model and hide the original, this will allow you to select keypoints and apply Synchronous operations. Or, it could be the geometry came in as non-solid. See link for a discussion on the forum.
bnagel made a good point. Make sure sure your selection filter is set properly.
Thank's a lot ...... filter......mmmm what a stupid mistake.
Respect
Amnon
