1 Attachment(s)
Solidworks CAM Post Processor for Mach 3 machines.
Hello Tormach Owners,
I have been searching for a post processor to allow me to use Solidworks CAM on my Mach 3 style PCNC 1100.
Unfortunately I wasn't able to find anything suitable, so I have generated a version myself.
This post is not fully tested but appears to generate code similar to that generated by Sprutcam.
If anyone wishes to use this, please do so with caution.
If you have any feedback I'd be happy to continue modifying the PP.
Please note that this PP is for metric settings.
Re: Solidworks CAM Post Processor for Mach 3 machines.
True, but if you've got a pile of gcode files that run on the Mach 3 version, you might want the ability to continue using them, and I'm not sure whether this is the case if you upgrade to Path Pilot.
Quote:
Originally Posted by
JTulley
any file that runs on Mach 3 will run on Pathpilot at least in my case that was never a problem
Thanks, that's good to know.
popspipes
Yep, I have files I coded years ago running Mach3 they work fine with PP when I use them now.
Good Morning, hope you can assist, I have a Mach 3 controller and Solidworks 2019, when I run the post it says its out of date, (The Licence)
How do I go about obtaining the correct Post processor from SolidWorks 2019 to Mach 3
Regards
PIerre
