Software and controller recommendations for ROUTER
I have been CNC machining for years now using Surf-Cam and a 3 axis Milling center. This is high production with very tight tolerances.
I make things out of thermal sheet plastic and use the CNC primarily to build my own molds and fixtures from aluminum and steel.
Recently I purchased a Wart Hog CNC Router to help with trimming operations of the molded plastic parts. It seems to be a fine machine however I’m not getting everything out of it that I would like.
First the controller (win CNC) is pitiful offering a very limited selection of features compared to what I’m used to.
2nd is that when trimming around a 3D part the thing is very inconsistent in the Z axis. I can’t put my finger on why. Any ideas about this? The Z axis holds fine and repeats fairly accurately when we are cutting 2D projects but not with flowing 3D edges.
3rd I need a good production nesting software. I need to be able to take several different shape parts, designate how many of each I need, get automatic tabs, and track the left over scrap geometry so as to use that for following projects. Anything like that out there?
4th I want to keep this machine running as much as possible so as to get my money’s worth. Surf-Cam is great for the CNC mill but I’m looking for something better suited toward the Routers. Something that will give us capability as far as graphics, such as signs and plaques, is intuitive, converts a broad range of file types, and offers quality tool path generation and post processor. What do you guys recommend?
I am new at this, so take this with a grain of salt.....
I am using a WinCNC setup on my Shop Sabre and it is working just fine. The machine is a ballscrew setup on all axes. I don't really like its proprietary interface, but I didn't know anything about CNC at the time that I made the purchase. However, I have had no problems with 3D cutting or with my 4th axis unit. I am running a dual Z-Axis setup and also have a digitizing probe.
The one thing that I liked about my Shop Sabre purchase was that they (Shop Sabre) had me ship the computer to them. They installed the interface and the software and then set everything up before they shipped my machine. I truly believe this is why my machine has been completely dependable and accurate since I took it out of the crate. I also built my own control computer instead of just buying a Dell, etc. Since my area of expertise was the computer, I know that I have quality components throughout and that the computer is maximized to its fullest.
Knowing what I know now, I would probably not use WinCNC controls on a new machine and will probably upgrade my controls on the Shop Sabre if I ever start having trouble with them.
I have been using Xylotex controls and Mach 3 software on a little desktop CNC that I purchased for testing and educational purposes. I REALLY like the Mach 3 software but had some problems with the Xylotex controller.
I am using BobCAD/CAM, BobArt ProX and BobNest for my production software. I don't think much of their company, but their software has been working well and there is a lot of support for it out there in the forums.
