Hello guys i have change the ucmb reload the parameters And Im getting this alarm p 955 . Machine serial number . It must be chamge Somehow?
Allex
Printable View
Allex
You must reinstall software before restore parameter
I have done the initialize memory disk, i getting this 955
0955 Spec. code: data file
[Code] ABCCCCCC
A:
1-> NC specification code file (FR0A:)
2-> EC specification code file (FR0A:)
3-> NC specification code file for PLC created by MTB (FR0G:)
4-> NC specification code file for PLC created by MTB (MD0G:)
B:
1-> No file is found.
SECTION 3 ALARM P
4187-E P-74-R2
2-> File attribute and sector size do not conform to ’SPC1’.
3-> Mismatch of the machine number
3-> Mismatch of the machine name
4-> Mismatch of the specification code data
6= -
7= Mismatch of the specification code data (such as machine number, machine name, and coded data)
except for the data stored in the specification code change file
8= The file is not OSP-formatted.
9= File open error
A= File read error
CCCCCC: 000000 ... BÅÇ5
XXYYZZ ... B=5
XX: Byte position of the mismatched specification code
YY: Mismatched specification code data
ZZ: Specification code data (before change
An and if i make this FR instal im getting this 152
152 Memory disk ROM write
An error occurred in data writing onto the memory disk (FR).
[Character-string]
Start of writingThe transition from read-only mode to program mode does not take place.
End of writing The transition from program mode to read-only mode does not take place.
Verify Verification proved that the data written onto the memory disk (FR) did not match the original data.
Element deleteElement in the memory disk cannot be deleted.
Running task During task running, writing was attempted onto the memory disk (FR).
[Code]
1-> An error occurred in the memory board No. 1.
2-> An error occurred in the memory board No. 2.
XXXXXXXX->Address near the error location
[Probable Faulty Locations]
1) Defective memory disk (FR)
2) Defective control software (in the case of task running)
[Measures to Take]
Change the memory board or flash memory card causing the error. * Correct the control software (in the case of
task running).
It can be a size problem ?? i had a 8m flash memory and now its a 16mb
initializing MD and installing software is not the same thing.
