Re: 770M Initial impressions
I noticed they posted the approximate cost to upgrade your m to servos in the near future.
Quote:
Originally Posted by
mountaindew
Can you point me to that? I haven't seen it, and don't see it on the Tormach blog or website anywhere.
tmarks11
Can you point me to that? I haven't seen it, and don't see it on the Tormach bog or website anywhere.
https://www.tormach.com/1100mx/
Servo Motor Upgrade Kit
Get the speed you desire before mid-year with a servo motor upgrade. Servo motors on the table (X-, Y-) and Z-axes increase throughput by providing higher accelerations and faster rapids.
Targeted Availability: April 2019
Price: $1995
$2k for 3 axes worth of servos and drives sounds pretty reasonable to me. Is it?
MichaelHenry
In my opinion it is. We will likely go that route with this machine soon.
WW
If it improves the smoothness of things (I notice faceting on arcs on my 1100) I could see a benefit there, but in most cases aren't your cutting speeds going to be more limited by the 10k spindle and limited rigidity than anything else? $2k isn't outrageously expensive, but if it's mostly for bragging rights....
If the servos have absolute position sensors, then you may be able to recover from crashes/overloads without having to re-establish your reference.
Other than that, it seems like the servos are mostly about the rapids being faster, thus spending less time not cutting. That will certainly feel better for someone standing there and looking at it. Is a good feeling worth $2k? Might be!
jwatte
Every once in a while I check simulated times to machine a part using SprutCAM, which defaults to 500 ipm rapid speeds instead of the actual speed (120 ipm?). The difference in estimated total job time between 500 ipm and 120 ipm is usually not enough for me to be concerned. I'm manually changing tools and usually running 10 parts on less on a job, though. Watching the Tormach rapids sure seems like a lot slower at times, though.
MichaelHenry
Yes, I find there is minimal difference in SprutCAM times and actual times even when running multiple tools with a 30min run time using ATCs. I think the biggest time savings will be tool change time.
