line renumbering howto?
What's the easy way to renumber lines of code, set line increments, etc with Mach3? Currently I'm using Notepad which frankly bites, or else I don't know how to use it properly. This issue came up when running the roadrunner.tap sample code. Everything stopped part way through. Suspect the demo code limit was reached.
signed
A linux user in foreign territory
Probably the limit. Mach3 will just stop at about 1000 lines of code.
You could load it into Excel as a space delimited file, and quickly add line numbers in there. Insert a column, enter 1 in the A1 cell, and drag down.
Excel, will check to see if I have that. Found NCPlot which does a very nice job of renumbering plus has some other useful features.
Yep, roadrunner is in the 4000 line range. Explains the stoppage pretty clearly.
Here's a great program:
http://www.editcnc.com/
