3 Attachment(s)
what is wrong with the code?
this is a screenshot of my machine when it threw the reset. I can't tell why. It should have raised up to be ready for the next tool change.
What am I missing?
I would like to run the code in Predator editor but the simulation does not show the part being cut when I run the backplot.
In the Simulation in BC it dosen't show the G-code when it stops for a tool change.
the screenshot of the BC Simulation should be the same spot when it threw the reset.
Re: what is wrong with the code?
1 Attachment(s)
Ok,
Am I reading this right, it looks like the problem was "Z 0.628" didn't move like it should have?
so when it tried to do G 91 it threw the reset because it didn't come up before moving in x or y. I would like for it raise in Z and not move anywhere else. I have tried to figure out where it gets its xyz setting to move to. I have looked in Mach3 setting and haven't found anything that works or make a difference. every time when Mach 3 gets to the end of a program it moves to a spot that is relative to the job, not the same location xyz every time, so G91? relative to what?
Quote:
Originally Posted by
dlaery
It's a steep old learning curve but CAM doesn't produce G Code, CAM produces a Move List, your Post Processor is used to interpret the move list and generate G Code.
Start by explaining what you are trying to achieve and why you have chosen to use G91, until you do that what we have here is a mechanic who keeps coming back to the stores with a broken screwdriver and asking for a replacement without telling the store keeper that he's using it as a lever to lift a locomotive ;-)
I only use G91 because that is what was in the millpost provided by Bobcad when i bought this 8 years ago. everytime I upgrade there are some changes that I notice in the millpost in the next versions. So are you saying the tool did not raise because of G91?
then I will have to go into the millpost and figure out how to change that, seems easy.
this is what it shows at the begining of that operation:
Code:
T2 M06 (14 EM)
G90 S10000 M03
G00 G54 X-2.1443 Y-1.075
G43 H2 Z0.628
M08
Z-0.175
Z-0.275
G01 Z-0.375 F10.
Z-0.3953
G17 G03 X-2.1443 Y-0.925 I0. J0.075
so it started out with G90
I am just trying to figure out how to use a screwdriver.
I remember a tool company that had guarantee on their screw drives, they would replace if they were broken, it they were bent or wore out they didn't replace them.
dlaery
Code:
T2 M06 (14 EM)
G90 S10000 M03
G43 H2 Z0.628
M08
Z-0.175
Z-0.275
G01 Z-0.375 F10.
Z-0.3953
You did not tell it what to do
G91 is just a mode Incremental move G28 is how it is going to move so would of needed a G0 or a G1
G91G28G0Z0. This will work
G91G28G1Z0F20. This will work
And to make it as simple as it should be
G0Z0. is all that is needed
You should not use a G91 or a G28 unless you have an reason to use it
dlaery
Yes, but it did say on the handle "Not for use as a pry bar or chisel" :D
You can use the G Code commenter here - G-Code Commenter
to tell you what most of your code is doing -
T2 M06 (14 EM) ( T:Tool Number:2 M06:Tool change )
G90 S10000 M03 ( G90:Absolute prog S:Spindle Speed:10000 M03:Spindle On )
G00 G54 X-2.1443 Y-1.075 ( G00:Rapid positioning G54:Zero offset #1 )
G43 H2 Z0.628 ( G43:Tool offset compensation positive H:Tool length offset index:2 )
M08 ( M08:Flood coolant on )
Z-0.175
Z-0.275
G01 Z-0.375 F10. ( G01:Linear interpolation F:Feedrate:10. )
Z-0.3953
G17 G03 X-2.1443 Y-0.925 I0. J0.075 ( G17:X-Y plane selection G03:CCW circular/helical interpolation I:X axis offset for arcs:0. J:Y axis offset for arcs:0.075 )
