Engraving mild/hot rolled steel ideas?
I'm looking to engrave a small logo 1" in size into mild/hot rolled steel. Doesn't have to be very deep. I've looked at lasers but I would need a fibre laser. A CNC mill might work but not sure. My budget is 1k so I know I'm limited. Any other ideas?
Re: Engraving mild/hot rolled steel ideas?
A pencil grinder in the lathe toolpost and a CNC controlled lathe.
Quote:
Originally Posted by
hfjbuis
I don't think a lathe would work. I forgot to mention that the logo is small but the piece of steel is 16"x16".
Frizzo
Can't send you dm
I have fiber laser.
Sent from my MHA-L29 using Tapatalk
ChrisW
Can't send you dm
I have fiber laser.
Fibre lasers are out of my price range.
Frizzo
I can engrave it for you.
I have co2 Engraving you can use Cermark spray to engrave in black
You can buy these under 1k
Or
This
https://gtschmidt.com/pin-marking
Etching
https://youtu.be/ncWXVOzNGbA
Reverse logo stamp. https://uploads.tapatalk-cdn.com/201...594ed25a11.jpg
Yes stainless would work also
Frizzo
Do you know what material the stamp would have to be made of?
Would a stainless steel stamp work?
This one was mild steel
I suggest tool steel and heat treat then it should work
I can do it on hardened tool steel.
