hypertherm 1000 g3 scaled arc settings??
Having issues with plasma table. Using a hypertherm 1000 g3. Scaled arc voltage on plasma table was set at 5volts. Looking in manual it says "full arc voltage. No voltage divider. 300vdc maximum. Does this mean I should have the machine set to 300volts?? I've been cutting 1/4" and 16 gage for a bit and it's been working fine. Switched to 1/2" material and struggling with getting decent consistent performance.
Re: hypertherm 1000 g3 scaled arc settings??
What brand and model cnc plasma table? The arc voltage that can be measured inside the Powermax1000 is used as feedback for your cnc machine or height control to control torch to work distance. To help you we need to know what table you have, as well as interface connections between the Powermax and the table. Jim Colt
