Hurco KM-3 with Ultimax 2 Controller
I recently picked up a Hurco KM-3 with Ultimax 2 controller. It worked fine at first, but this is what I get now:
First screen at start-up says "Executing Power Up Diagnostics" (normal), but the next screen it goes to is not normal. It is the "Machine Configuration" screen, which states the maximum travel for the axes in mm.
I found a note with the manuals that said if this happens to press Enter 639 Enter, then press 0 Enter, then press softkey 8 "Exit", then press Enter 999 Enter. I did this when it happened a couple of days ago and the machine reset and everything was fine. Today, those codes do not work. One difference between today and before is that at the "Machine Configuration" screen, the parameters for the max. travels are all at "-0.03mm", where before they were somewhere around 650mm for X, ~ 225mm for Y and ~ 127mm for Z.
If you know of any "magic codes" or anything I can try, it would be greatly appreciated. Also, if you know of what might be causing this, please let me know.
Thank you....
