stainless hex and track bearings.
After spending too many hours reading the posts here, I've decided to take on prototyping a simple router based around 11/16" stainless hex rod, LV 20/7 ZZ yi-tong 120 degree bearings. (http://www.yi-tong.com/en/vee_bearings.htm).
I made a quick gantry (in the living room) out of 40mm 80/20 surplus extrusion. I took two sections 48" stainless hex and taped it down to rails, just for fun. I used shopbot 1 to cut a piece of 12mm baltic with a 8 mounting holes (4 on each side) to hold 7mm shoulder bolts. I ground the
heads on the shoulder bolts down to about 1/16 to the extrusion and used a few washers to lift the bearings off the board to clear the hex rod. I had to also grind the edges off the hex as yitong bearings have a 2mm (?) flat and hex rod doesn't have a flat on the points.
so using bearings to pinch the rod and adjust out the slop, it moved suprisingly easy and was quite slop free. So I secured the hex rods as securely as I could and rode the gantry like a shopping cart.
Since I only had 2 pieces of hex, I made another large frame for the prototype x axis, cut two more pieces for the ends of the gantry, 4 holes each to pinch the hex rod. It seemed to work so well, I climbed on it. Seemed pretty tight. I quickly weighed the prototype gantry. 40 lbs.
so far, so cheap.
bearings - 10ea (8 per axis) $80
hex rod - $60 (that's 6 5 foot sections of 416 from ebay)
80/20 40mm 6ft*50 ft (?) $300
baltic birch $ 5
misc corner braces/screws $100
thk style rails for the z $50
about 600 or so.
Now I want to mount the rails without drilling them. I thinking about 4905 3m vhb tape. I know that's not necessarily the most accurate way to do it, but it will allow one to "rerail" their system with a piece of piano wire, a quick grind, and $15 worth of vhb 3 times before recycling the rails.
on the x axis, I plan to place the hex down flat, and I'm trying to decide whether to hang the rails on the side for the y axis (makes the gantry slide a simple plate of aluminum in the nonproto), or do like joe did, top and bottom of the y axis.
there's nothing that precludes this design from being relatively cheap and big...
so what's the cheap accurate way to drive a 8 ft x axis? I figure that rack is cheap if you make your own gearboxes. vhb will hold that down the rack too (shopbot does it). the only hangup I have with rack is that you really need gearing to make it work right. can gearing be avoided with belt drive?
the third option is a spinning a delren nut around a fixed acme rod, but i've not seen many good examples here to look at.
the y axis, i'll probably use 1/2-10 2 start and a dumpster nut.
I guess that's a few questions. I'm hoping to bring in prototype 1 with 48" rails x and y for under 1200, motors and all.
J
