Re: Need advice on milling
There are lots of factors besides those you mentioned. Could you provide some specifics like chip color, material? Maybe a picture of the setup used? I surface lots of different things that are not held conventionally in a vice.
chip color is blue and the heat is definitly leaving with the chip as the parts arent hot. the material is steel with a hardness level of around 55 rockwell thats heat treated. Ill try and get a better picture of the set up here in a bit.
hy :) at 1st glance, at 500 you may be out of torque, and rpm motion may be discotinued and that means more stress for the inserts; also, considering your specs, and those 55hrc, then what is your machine type ? .06-.1 = ap, ae ?
also, before rapid back, be sure that you dwell for at least 1 full revo
if possible, try to locate the position, during machining that leads to that chipping; is it somehow always happening to the saame insert seat ?
Quote:
we are feeding to the centerline of the cutter then rapiding back
a picture would be nice / kindly :)
ill look into that. what does the dwell for one full revo do exactly? make sure the material is faced completely?
1 Attachment(s)
