Emco 325-II (Fanuc 21TB) live tool alarms
Need some help with my 325-II (Fanuc 21TB) if anyone's run in to this problem or has an idea.
Trying to use the live tools and I'm getting two alarms when I activate the M-codes.
Commands:
M52 (C-axis on)
G97 Sxxxx M13
As soon as the M13 (or M14) is called the live tool engages (I can hear the solenoid) and rotates 1/4 turn then it throws an alarm and the C-axis and live tool disengages.
Alarms:
8132 AXIS ACCESSED BY MULTIPLE CHANNELS
8203 FATAL AC ERROR (0-PTR IPO)
Both alarms are in the programming manual, but are cryptic:
Cause: Internal error
Remedy: Restart software or reinstall when necessary, report to EMCO, if repeatable
I've re-started WinNC, no luck. Happens in MDI and during normal program execution.
Live tools worked last year, but I haven't tried using them in about 10 months. No crashes or major problems/maintenance since they last worked.
Maybe the G-code syntax is wrong? The Emco manual is pretty terrible...
Anyone have suggestions?
Ralph
Re: Emco 325-II (Fanuc 21TB) live tool alarms
M5 before M52. I ran cross your post somewhere about tapping with live tools. I've only been successful with G33.
Quote:
Originally Posted by
Diesel_Pilot
You're thinking this, right?
M5
M52
G97 S5000 M13
Doesn't make sense to me as it alarmed when I was using MDI one line at a time. The spindle wasn't running (in spindle mode), and I could do an M52 and then jog the C-axis just fine. It only threw up when I tried to engage the M13.
But Emco is insane and anything's possible.
After some serious searching, I found a single example in the Emco 21TB programming manual (ver C2003-7) on page D49
G90 G40 G95
T0909
M52
G28 G0 C0
M13
G97 S5000
I wonder if the order is the difference? i.e. M13 on a separate line before the S-word.
Thanks for the advice regardless of outcome. I'll have a go with both versions a bit later tonight.
-Ralph
(SOLVED) Emco 325-II (Fanuc 21TB) live tool alarms
Changing the g-code order and adding a pause did the trick.
M52 (C-axis on, also homes C-axis so no need for)
M13 (live tool CW)
G4 X1 (needed pause before the speed command. No pause = alarm)
G97 Sxxxx (spindle speed)
Subsequent speed changes or start/stop/reverse don't require a G4 pause as long as the M52 is active.
Now I've just got to try editing my post so it outputs correctly.
Thanks for the help Diesel_Pilot!
