When i try to mill a cirkle or a line. The machine make a smal stop for each raw in prg. I think its some parameter i need to change. Someone who know this issue ?
Printable View
If I understand correct:
Your shape on alluminum consists of arcs and straight segments and you want perfect surface without marks where arc is connected to straight line. Right?
hy angorgus :) use this at the begining of your program : VINPX=0.0 VINPY=0.0 VINPZ=0.0 (VINPA=0.0)
if it doesn't work, then try to check your tolerance parameters / kindly :)
ps : hy bunny
hello again :) using vinp=0 may be dangerious, and may lead to interference ( for example when drilling/tapping multiple holes ); try using 0.013, and if you will ever need to deliver something more accurate, then simply lower that value; do you know how vinp works ? do you wish for more explanations ?
for the rest 5%, please share more details / kindly :)
ps : thank you mr wizard for your lessons :)
most toolpaths are a row of geometrical entities : lines & arches; let's simplify and consider that there are only lines; now, let's simplify even more, and consider that there are only 2 lines, perpendicular : one among x, and other among y, and each line's length is 100; coordinates :
... line 1 : point A(0,0) point B(100,0)
... line 2 : point B(100,0) point C(100,150)
in reality, when machine will begin to cut line 2, it won't be at point B, but a bit before it; machining, cutting, is not about absolute values, but about relative values; for example, if the machine will begin cutting line 2 when being at coordinate:
... (99.998,0), thus at B-0.002, thus in a vecinity of 0.002 arround B, then i guess you will be satisfied
... (90,0), thus in a vecinity of 10 arround B, then i guess you will have questions :)
vinp is a parameter for vecinity :
... vinpx : for x axis
... vinpz : for z axis
and so on, there is a vinp for each axis, including rotary axis ( for example when having a 4th axis or a trunion ), and others
if you need to machine a dimension that is tolerated at 0.005, then it may be better to use vinp<0.005, but also, okuma machines are pretty steady in their own
your vinp value was too small, thus making the machine to lose time, by performing suplimentary check, thus machine was moving at a precision that was too much for your parts :)
for mills, lowest vinp is 0.001, and highest is between 1 and 10; vinp 0 doesn't mean that accuracy is at it's best, but that accuracy control is no longer done via parameter input from operator, thus, if you use vinp 0, then you no longer control the accuracy, but leave it to the cnc to decide :) on lathes, vinp 0 will actually trigger the best accuracy (<1um), while accuracy control mode is no longer toogled by vinp<>0, but by g code (65 64) / kindly :)
hello again superman :) you are correct about those g codes
please, there is something that i don't understand; if i change vinp on a :
... lathe, nothing will happen, unless i use g65
... mill, then also real motion will change, even if i don't use g61; so what's the point of using g61 ? i have mill programs without g61, that begin with vinp 0, later change to custom vinp values, then revert to vinp 0, and they work; i know this trick from when mr wizard shared his oslow & ofast soubroutines
as a side note, i wonder why angorgus only hit 95%, and not full 100 / kindly :)
hy, something is fishy, because 0.015 should work much faster than 0.005
0.005 - duration 1
0.015 - duration 2
0.150 - duration 3
in reality, duration 3 < duration 2 < duration 1, while, in your case, this is not happening
please, provide more data, or something, so to see what you see; what type of control do you have ? pls share testing program / kindly :)
Hi
I have test 0.005 and 0.015. 0.005 is working with very very smal stop. 0.015 is not working. I get smal stop.
Krg
GG
pls share your test program
G95 S1000 F50 may be too much for vinp testing; that is close to rapid speed, and it may be possible that you are not even getting close to that feed during cutting
try this toolpath in xy plane : _|?|_|?|_|?|, no rad comp, keep things simple, be sure that you reach programmed feed, like for example, if line length is 100, then use a feed that will execute each line in 10 seconds; let's try S1000 F0.4, that's 400mm/min, so 100mm will execute in 1/4minutes; play with feeds, and vinp, but within a normal range
another simple toolpath in xz plane : |_|, z segment 100, x segment loooong, like close to max travel, and execute this in rapid; changing vinp should definetly show how 0.001 is slower than 0.1
sometimes it may be hard to spot a time difference, so a time system variable should help; try VC1=VDIN[1000]; if vdin does not work, then i don't know what does
you should look for a simple code, that will show how increasing vinp leads to less time duration / kindly :)
Why do you have active alarm? Maybe magazine interrupt is on? Please clear alarm. It seems as Superman says- exact stop is active. Did you check for M61? Are we seeing entire program with screen shot?
G94 may be desired on mill as stated.
Best regards,
hello mr wizard :) please, if i change vinp on :
... lathe, has no effect, unless g65 is used
... mill has immediat effect, even if i dont use g61
maybe at power on, lathe is g64(off), and mill is g61(on) ?
d alarm should have no effect / kindly :)
