Hurricane Laser Stepper Motor - Need help
Hurrican Laser is out of business, I own a 60 W Floyd Model. I need to replace the stepper motor, the information on the motor says: Type 57BYG059JXF CW#120215. I contacted gweicke several times and they have said they would get back to me but didn't. Does anyone know where I can purchase this type of motor or does anyone know of an equivalent. I don't know anything about the steppers and there are so many types online. This one has 4 wires and a 1/4" shaft, and a gear wheel under it with 23 teeth. It is for the Z axis, the belt is 10 mm wide. Any help would be greatly appreciated! I have called numerous stepper motor resellers and no one knows anything about this particular motor.
Re: Hurricane Laser Stepper Motor - Need help
Also, this is my first post, so if I did it incorrectly I apologize!!
how about add my whatsapp +8618560201508 then i send some 57 stepper motor data for you ,it should can be instead of old motor ,as we also make laser machine .
It’s probably nema 23 frame motor which is very common and available in many shaft sizes and lengths. Problem is that stepper motors don’t fail that often so it could be something else. I would check, tighten and clean all wiring connections first.
