Does anyone use the Tormach 440 for 1018 cold rolled steel?
Iām buying a 440 but can find too many specs on people using it for 1018 CR. I make small parts from .75ā x .50ā stock and want to know if it can handle a DOC of .25 with a WOC of .375 using a 3/8x2" .020" 4FL 1/2" F/L *AlCrN* end mill from Garr tooling. Thanks in advance
https://www.garrtool.com/search-results/?search=50494&material=&tool=&inch=Inch&fluteDiame ter=&numFlutes=&cornerRadius=&fluteLength=&reachLe ngth=&overallLength=&coating=#
Re: Does anyone use the Tormach 440 for 1018 cold rolled steel?
Sorry not .375 WOC but .075 WOC
Is there a specific reason for that particular tool and those specific cut parameters? I know the 440 will handle 1018 because I've done it (makerspace machine) and that was back when I had NO clue what I was doing. I don't know that it has the power to handle that big of a cut though. I suppose it will depend a bit on your chip load.
My opinion from what I have read over the last few years, I would go with the 770 as it has a much better rapor than the 440.
I have an 1100 s3 and it is a bit underpowered as well when using larger cutters.
.075 radial might be too much load on the 440's motor.
It might stall.
I would do more passes, with a lighter radial load. Maybe .015 per pass.
