Paneling question start...finish
Need help...ok...this paneling thing has me a bit confused.
If it returns home 0,0 after it cuts the first panel...then you pull your material through...how the heck do you make sure that the material is absolutly in the right place...if its off a centimeter..your cut will be off!
Why doesnt artcam after cutting the first panel simply raise(z) the tool where it stops then you can pull the material through and lower the z to make its in the right spot and start from that point?
sounds goofy to me to have it return to 0,0
Im I doing something wrong?
Does someone know a way of doing this?
Thanks!!!!
