Hard disk problem - osp-u100m
Hello everyone
i have osp-u100m machine and suddenly i got error msg:
5427 DNC-DT Program select error 80000099 and when I checked the control I found a noise coming from the hard disk case and the LED turned into red and buzz started to make noise
does anyone know the solution for this problem ?
Re: Hard disk problem - osp-u100m
is this harddisk 3.5" ide?
Quote:
Originally Posted by
saeedmohamed
Hello everyone
HDD may have a bad block or worn out bearings. so if possible turn and run the HDD upside down to use top bearings, until you get the HDD replaced
1 Attachment(s)
reuelt
Thanks for replying can you explain to me how can i do it? because now I can only get one LED on and the other turn on for a few seconds and turned off again as shown in the pic. i did a test over my computer by connecting HDD and it look fine and working
one more hint, I got other HDDs but the machine cant detect them is it a reason for initialization?
1 Attachment(s)
kurmay
Similar to the one in the attached picture. but i have RAID Drive 1 and Drive 2 total around 5 or 4 GB
