SETP wrong turret, Froze loading screen
Hello,
in SETP (Parameters) window i choose by mistake wrong turret. When i HIT MANUAL to confirm, FADAL froze instantly. I shutdown FADAL for 5mins, and when i turned it up, i can see only FADAL Logo on screen and nothing happens. Cant even get to cold-start screen. Is there a way, to lose all data, and start everything from first steps?
Re: SETP wrong turret, Froze loading screen
You most likely short the battery out for a few seconds like a cmos battery it will wipe all the memory and settings. I believe removing the cpu card then removing the RAM card from the cpu board for a few minutes will discharge it and wipe the memory. It seems to have done it each time I've done that.
There is also a Bat Test button and a reset button on the edge of the CPU card. I have no idea if holding reset will clear the settings. I hadn't found any information about it.
When i press Battery test button, LED doesnt blink.
When i push restart button, something is happening. But it doesnt change situation.
Seems, i have to take cards out, like you said.
Thank you.
What ended up working?
Quote:
Originally Posted by
Ernis
yes, i did
