Thermal shutdown-overload on 7x12??
I have been having some issues lately with my lathe shutting down on me. For instance I was cutting a 1/8 wide slot in the inside of a piece of 2.5" round 360 Brass. Sharp carbide, slow cutter feed speed. Then click the lathe shuts off. Move the speed control back to off then restart everything works fine until a minute or so later then same thing all over. It done it a few times threading also. Could something be binding? I wasent using the carriage feed so it wasent that. I could attribute the threading to the carriage feed since I found it was binding when I was threading. 13 TPI and it would kick without making a cut just feeding by itself. Loosened the right side leadscrew mount up and let it center itself and no more binding with it. What do you all think? Thanks in advance.
