Re: Path doesn't make sense.
The code finishes on Y=0. If the machine doesn't go there it probably has some backlash. Code has nothing to do with it.
Thank you for the reassurance. I checked the path on this website, but there must be a bug in the plot.
https://ncviewer.com/
Quote:
Originally Posted by
Routeron
When I import your G-code in CamBam, it shows perfect arcs ending at Y=0. So the code is fine, must be an error in the simulation.
I too ran your code and it works as written.
CitizenOfDreams
Thank you, I appreciate the check.
Thank you, Formantjim.
It's a strange one, as I've found ncviewer useful in the past, but now I'll need to double-check elsewhere.
The free version of NC Plot Ver 1.2 plots this correctly as well.
