TS-15 multiple alarms on startup
Hi everyone. I have a new to me TS-15 with the Seicos E21 (fanuc 21i-t) control. Just got it powered up. Hydraulic pump comes up and makes pressure, so I believe the wiring is correct. I can't get any movement out of the machine and have the alarms as shown in the picture. It was suggested in another group that I had lost parameters and need to reload them. That was the only response I got, so trying to confirm that or see if there are any other recommendations. Thanks!
Chrishttps://uploads.tapatalk-cdn.com/202...d628d8696c.jpg
Sent from my SM-N960U using Tapatalk
Re: TS-15 multiple alarms on startup
Update:
Reloaded the parameters and have the machine up and running. Got everything cleared up except the F300 alarm shown at the top of the screen. Everything physically seems to work except the turret index and the spindle will only jog. I believe I need to home the turret, can anyone help with the procedure? Did some searching and can't find the actual procedure spelled out. Also, I can't seem to input anything into MDI or load any programs. Feel like it may have something to do with the "Directory Broken !!" Shown in the one screen. Any ideas? Thanks!https://uploads.tapatalk-cdn.com/202...65f0d25af9.jpghttps://uploads.tapatalk-cdn.com/202...b1d52a227d.jpg
Chris
I’ll send you the procedure to reset that, and the broken directory as well!
